I am trying to program a code for the MIXMRT 1020 MCU. I have issue with dealing with .bss file being too large. The SRAM_DTC region overflowed by 2952184 bytes. I tried looking at documentation on flexram_ram_allocate sdk example code. I look through the reference manual and it says that I could only allocate up to 256 KB. I was wondering if somehow I could allocate the .bss file to the SDRAM or flash.
Solved! Go to Solution.
1) I was wondering if somehow I could allocate the .bss file to the SDRAM or flash.
-- Of course, you can make it via modifying the linker file.
Regarding linker modification, please refer to the user guide of the specific IDE.
TIC
TIC
