hy,
i think you should give more information. (Borad,BSP)
you can check if this image is available with:
bitbake -s |grep image
after this you can build the prefered image using:
bitbake *image name*
the board I am using is imx9q sabre lite,I tried with bitbake core-image-x11 -c populate_sdk.But I am not getting a .sdcard file in deploy directory.Which is suited for me to make some gui using qt
Hi SREEKANTH
one can look at qt for boundary devices boards
Boundary Devices i.MX6 Boards | Qt 5.5 for Device Creation
i.MX Yocto Project: Frequently Asked Questions
after bitbake is running successfully. whats in your /build/deploy/images/ directory?
i think you can set the image type in local.conf with:
IMAGE_FSTYPES += "sdcard"
but i'm not shure.maybe justr try. but before check the deploy folder
