I use dylan branch of fsl-image-gui to test vpu, use the video player I can play
*.flv, *.mp4(720p and 1080p), but *.avi not work.
i.MX6Q can play rmvb?
By the way, How to test vpu in system?
GPU of dylan branch is ok?
Solved! Go to Solution.
Please do not use that set of branches (dylan branches). Use 'dora' instead.
To see which codecs are supported, you can use the 'gst-inspect vpudec' command, and look at the sink pads.
Testing VPU can be done either with /unit_tests/* apps or gstreamer.
Hello, I try to play ***.wmv, the player pop "GStreamer is missing a plugin", "ASF demuxer is need install".
gst-inspect vpudec show it can decode wmv, so I guess the asf is need to install to decode *.wmv to got the audio?
