I am looking for source code for the executable in /opt/viv_samples/vdk. Anyone know where they are?
I'm using Linux 5.10.72_2.2.0
According to the i.MX_Graphics_User's_Guide.pdf, it seems that you should install the VivanteIDE, part of VeriSiliconIDE associated with each BSP release.
K.
Thanks for the suggestion. I tried installing the VivanteIDE, part of VeriSiliconIDE, and didn't see any examples like there are installed in /opt/viv_samples/vdk/tutorial[1-7]. Looking at imx-gpu-viv-6.inc, it would seem the binaries are being directly downloaded from this url: SRC_URI = "${FSL_MIRROR}/${BPN}-${PV}.bin;fsl-eula=true"
It would be so nice to see the source code for the /opt/viv_samples/vdk/tutorial7 executable.
It can be downloaded from the following link https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-gpu-viv-6.4.3.p2.0-aarch64.bin
Once downloaded :
$ chmox +x imx-gpu-viv-6.4.3.p2.0-aarch64.bin
$ ./imx-gpu-viv-6.4.3.p2.0-aarch64.bin
All the necessary source and libraries are inside imx-gpu-viv-6.4.3.p2.0-aarch64.
Note that you might check related recipe for the right version of imx-gpu-viv-<version>-aarch64 in your Yocto BSP.
K.
It looks like Freescale/NXP does not want to publicize the source code of the mentioned examples. They provide prebuilt binaries aligned with each BSP version. And what you saw similar to mine.
K.
