Hi All,
Problem with video record and preview in Stream function with iMX8QM-MEK + Android 9 Automotive.
$ source/vendor/nxp-opensource/imx/libcamera3/Stream.cpp
-> if it enabled video recorded but recorded video is in green color
if (s->usage & GRALLOC_USAGE_HW_VIDEO_ENCODER)
-> if it not enabled video recorded and recorded video is proper.
if (!(s->usage & GRALLOC_USAGE_HW_VIDEO_ENCODER))
Thanks & Regards,
VinothS.
Is this problem solved? If so, can the patch be released
Hello VinothS,
Thanks for the catch! I´m going to send this to developer team in order to fix the android for MX8QM-MEK board.
Hello! Is this issue resolved? Please release the patch, thank you!
Thank you Bio_Ticfsl.
Thanks & Regards,
VinothS,
