I want to know the usage of IDMAC channel 5 in iMX6 IPU which transfer camera data thru VDIC to frame memory.
I tried to set as following but no interrupts happened.
CSI0_SENS_CONF = 0x04000A20 //YUV422(UYVY)
CSI0_CCIR_CODE_1 = 0x00040030
CSI0_CCIR_CODE_3 = 0x00FF0000
Obviously my setting was not enough. Which registers should I set and how?
Is there any sample codes or documents?
Can anyone help me?
Thanks.
Solved! Go to Solution.
Please look at the following
https://community.nxp.com/docs/DOC-330441
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
Yuri
