Unable to get the metdata information using gplay after using ‘>’: Play the next multimedia file.
884 次查看
srinivasanshanm
Dear I.MX Community,
I am using L2.6.35_1.1.0_130130_source on I>MX28 BSP,
I am unable to get the metadata information of the next multimedia file after  giving ‘>’: Play the next multimedia file.
Could you please help me out in how to resolve this issue, as am unable to get the metadata information of the next multimedia file getting played, I hereby attached the log for your information,
Kindly do the needful as early as possible, as am stuck with this issue from many days,
Many Thanks in advance
Original Attachment has been moved to: logs.txt.zip
标签 (2)
783 次查看
joanxie
I upload a patch which can fix this issue, pls use it and give me the response.
784 次查看
joanxie
783 次查看
GraceH
Senior Contributor II
I can reproduce the problem and CT 44525538 is created.
Grace
