USB camera not supported in IMX8MM(IMX8M MINI)
1,003件の閲覧回数
Ruban1
I am trying to RUN USB camera .its getting crashed in Android 10 OS
When i try with yocto using GStreamer its opening
But when i try with Android 10 OS its not openning
Can you Kindly provide related documents for Android OS for  USB camera
Thanks and regards
Ruban
3 返答(返信)
990件の閲覧回数
jimmychan
Please try the latest version of Android BSP. ( Android 11.0.0_2.2.0 )
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications...
According to the Release Notes (https://www.nxp.com.cn/docs/en/release-note/ANDROID_RELEASE_NOTES.pdf), USB camera supports C920, C270, and C525. Can only work with Camera2Basic app.
979件の閲覧回数
Ruban1
I even tried with Android 11.2.2 and with the same apk you have mentioned Camera2Basic app. Still it doesnot detect.
But i tried with yocto build and using Gstreamer it working fine . But Due to i am using Android i have to use only from application layer .I am facing problem in Application layer.
Can you provide guide lines.
Thanks and regards
Ruban
