USB camera not supported in IMX8MM
I am trying to RUN USB camera .its getting crashed in Android 10 OS
When i try with yocto using GStreamer its opening
But when i try with Android 10 OS its not openning
Can you Kindly provide related documents for Android OS for USB camera
Thanks and regards
Ruban
Please try the latest version of Android BSP. ( Android 11.0.0_2.2.0 )
According to the Release Notes (https://www.nxp.com.cn/docs/en/release-note/ANDROID_RELEASE_NOTES.pdf), USB camera supports C920, C270, and C525. Can only work with Camera2Basic app.
I even tried with Android 11.2.2 and with the same apk you have mentioned Camera2Basic app. Still it doesnot detect.
But i tried with yocto build and using Gstreamer it working fine . But Due to i am using Android i have to use only from application layer .I am facing problem in Application layer.
Can you provide guide lines.
Thanks and regards
Ruban
