Currently I'm working on imx8qm MEK with Android Auto 13, linux kernel version is v6.1.25.
I am trying to enable bluetooth function on the board by connecting a bluetooth USB dongle rtl8761bu.
To recognize the device and bring out the driver, btusb.ko and btrtl.ko are both necessary for this.
Here is my setting:
CONFIG_BT=m CONFIG_BT_RTL=m CONFIG_BT_HCIUART=m CONFIG_BT_HCIBTUSB=m CONFIG_BT_HCIBTUSB_RTL=y
-obj-$(CONFIG_BT_HCIBTUSB) += btusb.o +obj-m += btusb.o -obj-$(CONFIG_BT_RTL) += btrtl.o +obj-m += btrtl.o
After compile the kernel, both kernel modules are missing in the driver folder, why?
Solved! Go to Solution.
You need add your .ko files into /device/nxp/imx8q/mek_8q/SharedBoardConfig.mk, then the drivers will be copied into Android rootfs.
Best Regards
Zhiming
Best Regards
Zhiming
