How I can tune voltage swing to pass USB 3.0 compliance?
I am getting only: PeakToPeakVoltage (5G) (Short Channel) [32241] 63.3 mV, while Pass Limits: [100.0 mV to 1.2000 V]
Thank you.
Pavel
Solved! Go to Solution.
OK, got it, this is the magic:
1) Boot linux
2) memtool 0x5b198004=0x3f
3) memtool 0x5b198030=0x03
4) Plug USB fixture and conduct measurements
1) Boot linux
Hi Pavel,
thank you for sharing your solution. We are facing the same issue on our custom board based on imx8QM.
Can I ask you where did you find this information or USB3.0 PHY register map?
Thank you in advance.
Best Regards
Giuseppe Pagano
