UART serial port missing on IMX8QM
339 次查看
Lincoln_Dessen
Hi all,
 After I add two more pin configs in `arch/arm64/boot/dts/freescale/fsl-imx8qm-mek.dtsi` file:
uart3 serial port ttyLP3 is missing in /dev:
# dmesg | grep tty:
 ttyLP3 only shows up If I remove GPIO0_IO03 and GPIO0_IO04 configs.
Is there something wrong with my gpio setting in dts file?
标记 (1)
325 次查看
Lincoln_Dessen
It seems the cause is I configure the same pin twice on different places.
326 次查看
Lincoln_Dessen
