Hi all,
Now we are upgradeing Android 5.0 on MX6DL, and we find the u-boot version is newer than before. So it has lot of changes. and I found, before this uboot ,the board_init is like the process in this board.c as below:
But referring to Android™ User's Guide.pdf, we get the code from freescale, and this latest uboot build the following board.c because the macro CONFIG_SYS_GENERIC_BOARD is defined.
And now, could I undefine it to use the above way to board init? 3Q~
Hi tony
for Uboot porting one can look at attached document.
I do not think that it is possible to use board init as it was done
on old uboot. In general it may be suggested to post it on
uboot mail list
