Hello Members ,
I am trying to get Geexbox onto iMx6 , for that i am using Openbricks sdk which have given me the kernel image and rootfile system . Before trying the iMx6 with rootfs of openbricks i have tested it with the rootfs provided by freescale and the sabresd board is able to comfortably booting , loading kernel and mounting rootfs . But when i try the same thing with rootfs i got from Openbricks it got stuck right after the following line .
"VFS: Mounted root (nfs filesystem) on device 0:12.
Freeing init memory: 168K"
It doesnt respond after these lines . How do i fix it and get the prompt as i am getting with freescale rootfs ?
Thanks & Regards
Brajesh Sharma
Hi Brajesh,
The problem of "VFS: Mounted root (nfs filesystem) on device 0:12" is caused by network. You should restart the nfs service:
sudo /etc/init.d/nfs-kernel-server restart
Hope this can help you~~
Best Regards
Dan
Hi Dan ,
Thanks a lot for replying to my query . As you suggested i'v restarted the
nfs-server few times but still it is stuck at that point though there is no
such problem when i try with rootfs provided by freescale .
Do you have an idea what might be the problem here ?
Thanks & Regards
Brajesh Sharma
Hi Dan ,
I am using SabreSD (iMX6) board
Brajesh
hi ,
I was trying the same thing with root file system of geexbox for Cubox on
sabreSD since both have same imx6q but exactly same output came and stuck
at
if you have any idea about this please share !
Thanks& regards
Brajesh
Can you mount the same filesystem (FS) on your Linux host machine? can you boot and use the FS on a SD card?
Hi ,
Thanks for replying . I'v seen few user guides on how to setup SD card for
imx but all that is a bit complicated that using a NFS Server but i'll try
as you'r saying that may help . And i did'nt get you "Can you mount the
same filesystem (FS) on your Linux host machine?" . I have mounted FS on
linux machine from there i am using it as Network file system . Are you
asking me to do something else ?
I'll update soon after trying setting up the SD Card .
Thanks & Regards
Brajesh Sharma
On Tue, Nov 19, 2013 at 8:46 AM, Leonardo Sandoval Gonzalez <
Correct, you did the test I asked. Let us know the results of the SD case. How are you exporting your folder (post the /etc/exports file)?
Hi ,
As you asked i have tried to set up SD card also but no response from
Sabre. So after that i just loaded the card with u-boot image only by dd
command , but when i insert it in board no response at all though i am sure
boot switch mode is right since other card with u-boot is giving the u-boot
prompt but i dont have any idea how that card was partitioned or set-up .
Need suggestion on it from you since i am stuck in here since long time .
Regards & Thanks
Brajesh
Brajesh
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
Brajesh
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel
free to reply with an update to this discussion.
Yixing
Hi ,
I am trying to set up the SD card for android boo up as given on a
freeacale page :
https://community.freescale.com/docs/DOC-1232#jive_content_id_Additional_Resources
I have formatted and partitioned the card and loaded the images as
instructed there but still i cant get the even the bootloader . Although
there are few steps that i am confused with in the procedure . There is
no specific partition for u-boot and uImage i am copying them by dd command
in /dev/sdb by offset address and there are few more things in that page i
am having trouble with . I am trying to do this by my way or any other way
i find it on web , i'll update the results about it .
Thanks & Regards
Brajesh Sharma
Hi ,
For NFS my /etc/exports content is :
