Touch driver porting
845件の閲覧回数
chenhungwei
Hello everyone, I have touch driver problem need your help,
I use i.MX6Q with Yocto.
I have changed the new panel, the display is shown normally, but cannot touch(Please see the picture at bottom),
I have checked the DTS & GPIO are normally, the evtest is normally too(reporting the X-Y axis correctly),
I also check the following command and all of them are normally,
could anyone can help me to solve this issue?
ラベル(7)
3 返答(返信)
743件の閲覧回数
igorpadykov
Hi Chen
may be useful to check boundary devices touchscreen resources :
https://boundarydevices.com/tag/touch-screen/
Sabrelite: New FT5x06 touch screen and swapped Y (input_set_abs_params)
743件の閲覧回数
chenhungwei
Hi igorpadykov,
          Nice to receive your response, do you think this issue is caused by touch driver?
743件の閲覧回数
igorpadykov
yes I believe it may be caused by driver.
