There is no HDMI sound output when I choose 1024x768
1,893 次查看
jiangshao
Contributor V
I have a customized imx6dl sabresd board(Android4.2.2)。
I refered to imx6dl HDMI can't support 1024x768 ,  and now I can get 1024 x768 resolution through HDMI。
But there is no HDMI sound output when I choose 1024x768。
(If I choose 720p,There is sound output through HDMI)
I want to know why, and how to fix it?
标签 (3)
814 次查看
igorpadykov
Hi Jiang
strictly speaking 1024x768 is not supported by HDMI module
according to sect.33.4.3 Supported Video Mode i.MX6DQ Reference Manual
http://cache.nxp.com/files/soft_dev_tools/doc/support_info/iMX6DQPRM.pdf
So there may be issues with audio, as HDMI audio playback depends on HDMI pixel clock.
815 次查看
igorpadykov
Hi Jiang
814 次查看
jiangshao
Contributor V
Thank you for your reply.
814 次查看
mike_susen
Hi Jiang,
please see this document HDMI Audio Setting
Michal
