Hi there,
In i.MX6DL/Q GPU SDK, it is coming through with the several formats of the pixel data extended noted in gl2ext.h:
#define GL_VIV_YV12 0x8FC0
#define GL_VIV_NV12 0x8FC1
#define GL_VIV_YUY2 0x8FC2
#define GL_VIV_UYVY 0x8FC3
#define GL_VIV_NV21 0x8FC4
With GL_VIV_NV12 I am currently trying to render the textures, but the color quality being shown in display seems to be not as good as I expected.
As for the degradation, I could guess that this issue is related to the color coefficients used for converting from YUV (in that case, NV12) to RGB.
Perhaps,
could anyone comment the color coefficients used in Vivante GPU engine?
or could I adjust the color coefficients via any API?
Gyuro
Hi Gyuro
please check sect.2.4.1 Color space conversion from YUV to RGB
attached i.MX_6_Graphics_User's_Guide.pdf and sect.7.3.15 Video conversion Linux Guide
Hi igor,
Thanks for your reply.
Nevertheless, the section you noticed wasn't fitted to my point.
Basically, in order to convert the color space of yuv to rgb, all the coefficients should be known for linear combination.
To help your understanding, please see the formula below. (YUV - Wikipedia, the free encyclopedia)
That is just what I want to know.
Gyuro
