Dear all,
Our customer changed the following pin into the PWM output in the original board.
L7 pin => PWM1
K8 pin => PWM2
However, a pulse signal is outputted from these pins during the Boot.
On a MX28EVK of Freescale, these pins are DUART_TX and BACKLIGHT_PWM.
Their BSP is based on Linux_BSP of Freescale.
I think that they need to change a setup of these pins in U-Boot.
I understand that such a setup is performed by DCD table.
However, I was not able to find DCD table in Freescale Linux_BSP.
Would you teach the place where DCD tabel is indicated who sets up these pins?
Yuuki
已解决! 转到解答。
Hi yuuki
i.MX28 ROM does not use DCD table.
Initialization is performed in bootlets. You can search where
these pads are initialized in bootlets sources.
For example DDR EDE1116AEBG initialization is performed
in bootlets file:
ltib/RPM/Build/imx-bootlets-src-xxx/boot_prep/init-mx28.c
For obtaining linux bootlets sources:
1. ./ltib -m prep -p imx-bootlets
This command will put imx-bootlets source codes in the folder --
ltib/rpm/build/
2. modify sources
3. ./ltib -m scbuild -p imx-bootlets
This command will build new images.
L2.6.35_1.1.0_ER_SOURCE : i.MX28 Linux 2.6.35 Source Code
chip
Hi yuuki
in bootlets file:
ltib/rpm/build/
2. modify sources
chip
