System no response while  print out VPU blocking: timeout and rcu_sched_state
1,255件の閲覧回数
fdact
I was play mp4 file, then a period of time found that there was no reaction to the system.This phenomenon is the probability of occurrence that need to play video a long time . I will upload the log . Can you give some advice?
Thanks.
Original Attachment has been moved to: systen_hang_up_paly_mp4.log.zip
9 返答(返信)
993件の閲覧回数
igorpadykov
this is kernel error, also android is based on linux.
~igor
993件の閲覧回数
igorpadykov
do you see red in my previous post from 05.06.2016 21:29
click on red with mouse.
993件の閲覧回数
fdact
HI igor,
    Our board uses android OS, but the document is for ubuntu OS.
993件の閲覧回数
igorpadykov
please refer to attached file
993件の閲覧回数
fdact
Hi igorpadykon,
    I didn't find any attached file.
993件の閲覧回数
igorpadykov
Hi ferdinand
seems you are using L3.0.35 with gpu lib 4.6.9, this is very old,
suggest to upgrade at least to L3.0.101_4.1.1 as it fixed many gpu bugs:
Board Support Packages (38)
i.MX 6Quad, i.MX 6Dual, i.MX 6DualLite, i.MX 6Solo and i.MX 6Sololite
Linux BSP Source Code Files (REV L3.0.101_4.1.1.)
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/i.mx-applications-process...
993件の閲覧回数
fdact
Hi igorpadykon,
    Now the problem is still not resolved, you have any way?
993件の閲覧回数
fdact
Hi igorpadykov,
   Files IMX_MMCODEC_3.0.101_4.1.1_Bundle.tar.gz is for ubuntu os use it?
Thanks.
993件の閲覧回数
fdact
Thanks for your reply. I didn't know how to use IMX_MMCODEC_3.0.101_4.1.1_Bundle.tar.gz. Is there have any documentation for the use of this?
