Supply lcd not found, using dummy regulator [Yocto][imx6ul]
3,296件の閲覧回数
jaspernuytten
Hi all,
I'm trying to get a 8-bit interface TFT display working with imx6ul.
Therefore I have applied the following patch: Patch to support MPU 8080 LCD on iMX6UL and iMX7D
When booting the Kernel gives me the following log:
MIPI DSI driver module loaded
21c8000.lcdif supply lcd not found, using dummy regulator
mxsfb 21c8000.lcdif: failed to find mxc display driver
Console: switching to colour frame buffer device 30x40
mxsfb 21c8000.lcdif: initialized
How should I start to fix this issue?
I have looked to activate the display in U-boot but unfortunately this is not an option as the u-boot version used for my specific board does not include any LCDIF options.
Kind regards
ラベル(3)
2 返答(返信)
2,095件の閲覧回数
igorpadykov
Hi Jasper
i.MX6UL does not have mipi-dsi, please try to remove it from linux build.
2,095件の閲覧回数
jaspernuytten
Done, but as expected this does not change the situation... Any more advice?
