Serial console work only if ethernet configured
782件の閲覧回数
BrilliantovKiri
Senior Contributor I
Hello!
My hardware:
- module DART-MX6 Rev 1.2 DART-MX6 CPU: Freescale iMX6 | System on Module - Variscite
- board DART-DT6CustomBoard V1.1 VAR-DT6CustomBoard - Variscite
My sofware:
- Yocto Jethro
- linux-4.1.15
please see attached file
- busybox-1.25.0
- linux command line
~ # cat /proc/cmdline
noinitrd console=ttymxc0,115200 root=/dev/ram0 ip=off rdinit=/sbin/initux command line
- file /etc/inittab
~ # cat /etc/inittab
::sysinit:/etc/init.d/rcS
::respawn:/sbin/getty -L /dev/ttymxc0 115200
::restart:/sbin/init
::ctrlaltdel:/bin/umount -a -r
I have very strange problem - serial port work only if ethernet configured and active.
How can I solve this problem?
Thank you and excuse my bad english.
Original Attachment has been moved to: config.gz
ラベル(2)
タグ(1)
567件の閲覧回数
igorpadykov
Hi Kirill
there are no known conflicts between serial ports and ethernet
and one can try to debug it using AN4553 Using Open Source
Debugging Tools for Linux on i.MX Processors
http://cache.nxp.com/files/32bit/doc/app_note/AN4553.pdf
