Hi all,
I have a custom board having iMX6q processor and i am using Ltib L3.0.35_4.1.0
i have a Weimnor connected to it, at the base address 0x08000000.
I am able to read and write to it using memtools. However when i write try reading the same memory location using QT application, it gives me a Segmentation fault.
I guess it does not allow me to access the location. Can anyone suggest how i can read the Weim Nor flash using the Qt?
I have attached the Qt code.
Help would be appreciated.
regards,
nishad
Original Attachment has been moved to: mainwindow.cpp.zip
