I am trying to transfer the audio data from SAI interface to I2S interfaces of two different slaves (DAC & I2S In Slave). same data and clk lines are shared between the two slaves.
Do you have any suggestions / precautions to take care for me regarding the implementation.
Possibly any reference code or application note will be huge help.
Thank you, Sreedhar
Solved! Go to Solution.
Hi Sreedhar
for several devices one can use sai tdm option, please look at function fsl_sai_set_dai_tdm_slot() in
https://source.codeaurora.org/external/imx/linux-imx/tree/sound/soc/fsl/fsl_sai.c?h=imx_5.4.47_2.2.0
some examples:
Hi Sreedhar
some examples:
