Sometimes I randomly get a SIGSEGV error when gstreamer pipeline starts to run if I use vpu or ipu related plugins in the pipeline.
For example, I tested these pipelines below and these pipelines sometimes generate SIGSEGV error:
gst-launch-1.0 -ve videotestsrc ! imxvpuenc_h264 ! fakesink
gst-launch-1.0 -ve videotestsrc ! vpuenc_h264 ! fakesink
gst-launch-1.0 -ve videotestsrc ! textoverlay text=test ! vpuenc_h264 ! fakesink
gst-launch-1.0 -ve videotestsrc ! "video/x-raw, format=UYVY, width=320, height=240, framerate=25/1" ! imxvideoconvert_ipu ! "video/x-raw, format=I420, width=320, height=240, framerate=25/1" ! textoverlay text=deneme ! fakesink
gst-launch-1.0 -ve videotestsrc ! "video/x-raw, format=UYVY, width=320, height=240, framerate=25/1" ! imxvideoconvert_ipu ! "video/x-raw, format=I420, width=320, height=240, framerate=25/1" ! textoverlay text=test ! vpuenc_h264 ! matroskamux ! filesink location=test.mkv
gst-launch-1.0 -ve imxv4l2src ! textoverlay text=test ! vpuenc_h264 ! matroskamux ! filesink location=test.mkv
Since the pipelines containing vpu/ipu plugins do not always generate SIGSEGV error, I wrote a bash script like the one below:
#!/bin/sh
while [ 1 ]; do
gst-launch-1.0 -ve videotestsrc ! imxvpuenc_h264 ! fakesink &
sleep 10
pkill -SIGINT gst-launch-1.0
sleep 5
done
This is the error I get once in a while:
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
[INFO] ringBufferEnable 0, chromaInterleave 0, mapType 0, linear2TiledEnable 1
Caught SIGSEGV
#0 __libc_do_syscall () at ../sysdeps/unix/sysv/linux/arm/libc-do-syscall.S:46
#1 0x76d21bb0 in __GI___poll (fds=0x2155978, nfds=2, timeout=-1)
#2 0x76dde58c in ?? () from /usr/lib/libglib-2.0.so.0
Spinning. Please run 'gdb gst-launch-1.0 931' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
handling interrupt.
Interrupt: Stopping pipeline ...
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
free(): corrupted unsorted chunks
The information of my system:
yocto fsl-community-bsp version: rocko
gstreamer: 1.12.2
imx-gst1.0-plugin: 4.1.6
gstreamer1.0-plugins-imx: 0.13.0
linux-fslc-imx: 4.1-2.0.x-imx
PS: In yocto fsl-release-bsp imx-4.1.15-1.0.0_ga I did not have this kind of problem. So I tried to downgrade imx-gst1.0-plugin from v4.1.6 to v4.0.9 to see if the problem is about the version 4.1.6 of imx-gst1.0-plugin; but unfortunately the same problem occurred again and again. Thus I am suspicious that the problem stems from a bug in linux-fslc-imx v4.1-2.0.x-imx.
Please could you help me to find a way to solve this problem.
Best Regards.
已解决! 转到解答。
Hi tugay
reason may be due to mixing different plugins, for example
imxvpuenc_h264 is part gstreamer-imx plugins described on
trac.gateworks.com/wiki/Yocto/gstreamer
imx-gst1.0-plugins are described in NXP documentation: attached Release Notes and
its usage in Linux Guide sect.7 Multimedia.
Also fsl-community-bsp linux-fslc usually is used with gstreamer-imx plugins,
while imx-gst1.0-plugin with official "linux-imx" nxp linux releases:
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_4.1.15_2.0.0_ga
Below on post dated "@ Andreas Geißler on Aug 30, 2018 8:44 AM" there is more description
about differencies between linux-fslc and linux-imx bsps:
i.MX6 PCIe interrupt mapping changes during runtime
https://community.nxp.com/message/402940#402940
Hi tugay
Hi igorpadykov,
Thanks for your help. Unfortunately, it didn't work. I disabled imx-gst1.0-plugin and then I built yocto from scratch. I got the error below once in a while when "gst-launch-1.0 -ve videotestsrc ! imxvpuenc_h264 ! fakesink" starts to run:
Alignment trap: not handling instruction f4024aef at [<75e05290>]
Unhandled fault: alignment exception (0x811) at 0x75d065b8
pgd = d88e8000
[75d065b8] *pgd=68bc1831, *pte=1999f75f, *ppte=1999fc7f
From the links you shared I understand that NXP does not support fsl community bsp. Thus I gave up to solve this problem and I will use the yocto nxp officially supports. However, I bumped into another issue when I began to use nxp official yocto release.
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-rocko -m imx-4.9.88-2.0.0_ga.xml
repo sync
After I created a yocto build directory for machine imx6qdlsabresd, I realized that the default linux distro is linux-fslc-imx instead of linux-imx.
Here are my questions:
1. Does NXP officially support linux freescale community edition? If not, why does this yocto version use linux-fslc-imx as default linux distro?
2. Should I stick with linux-fslc-imx or should I switch back to linux-imx?
3. Since this yocto version uses linux-fslc-imx as default linux, can I say that NXP tested imx6qdlsabresd with this linux?
Thanks in advance.
Best regards.
Tugay
Hi Tugay
linux-fslc-imx is not supported by NXP, below part of i.MX6 PCIe interrupt mapping changes during runtime
"The fsl-community (which you have linked to in your reply) is supported by Octavio Salvador
and we, NXP, have no control on its content. Hence we do not support it."
it is matter of choice, there are different functionalities for both options and one can choose
which better suit custom design.
no. NXP do not test linux-fslc-imx. NXP tests own BSPs (https://source.codeaurora.org/external/imx/) described on
