SEMC
SEMC
945 次查看
ma123456
您好,
    我想使用SEMC连接FPGA,都需要哪些引脚呢,FPGA是需要模拟为SRAM么?
6 回复数
904 次查看
EdwinHz
Hi @ma123456,
Please look at the following community post where my colleague shares some useful resources about the connection of the RT with and FPGA. I believe you will find them useful: https://community.nxp.com/t5/i-MX-RT/MIMXRT1051-SEMC-connect-FPGA/m-p/1385947
Do let me know if you have further inquiries about this topic.
BR,
Edwin.
899 次查看
ma123456
您好,
不好意思,我还是不太清楚:
1、如果数据线和地址线都使用的话,是只有FPGA当做SDRAM这种方式吧,那这种方式,有很多其他的引脚,这个是需要的么
2、如果FPGA当做SRAM,那么其中的CE#与CRE信号是怎么使用呢
885 次查看
EdwinHz
Hi @ma123456,
1. Yes, the FPGA would have to be an SRAM-like device.
2. In order to provide a better answer for you, could you please specify what is the part number that you are currently using?
BR,
Edwin.
882 次查看
ma123456
1、大多数是将FPGA当做SRAM还是SDRAM呢,因为这两种使用的线数是不一样的,有哪些是必须的呢
2、芯片为RT1052
860 次查看
EdwinHz
Hi @ma123456,
The connection to the FPGA would be according to the "SRAM (ADMUX 16bit)" of the Table 25-6. SEMC Pin Mux Overview from the Reference Manual. In the case of unused signals like CE# and CRE, they can remain unconnected.
BR,
Edwin.
847 次查看
ma123456
有相关的参考例程么
