Hi Team,age
I am working on IMX8M EVK board. I tried to poweron the board using SDCard loaded with android prebuilt images.But the board is not booting up. With default android images flashed in EMMC board is booting up successfully. Boot up logs are checked with minicom.Able to see the logs with EMMC images but not with SDCard android images.
Kindly provide a solution to proceed.
Thanks & Regards,
C.Himabindu.
i.MX8MQ supports eMMC on SD1 port, and SD card on SD2 port.
So if you want to boot from SD2 port, BOOT CONFIGRATION should be correct, and BOOT_MODE[1:]=10.
See page11 of i.MX8MQ design file, Boot Fuse Table.
Try it, please!
Have a nice day!
B.R,
weidong
