Do I still need to have zero ohm resistors in place to split VDDARM and VDDARM_CAP to prevent internal leakage when using the SCM-iMX6D? or has this maybe been taken care of with all of the internal discretes?
Hi AMMANUEL
zero ohm resistors are usually used for debugging purposes
and can be removed in real design. Please use Chapter 4
Requirements for Power Management i.MX6 System Development User’s Guide
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
