Runing MFGTool with kernel 3.14 hangs with windows driver error
1,401 次查看
petarbajic
Im working on custom SabreSD board and I compiled U-boot 2015 and Kernel 3.14 for MFG firmware. When I run the tool it downloads u-boot, kernel, rootfs and dtb then jumps to OS. I see it boots u-boot and kernel in uart console, and then device disconnects from Windows 7 PC and it should connect again but Windows pops up error: "Device driver software was not successfully installed", and MFG Tool hangs with "No device Connected"...
Last UART log from kernel is:
g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
g_mass_storage gadget: g_mass_storage ready
Freeing unused kernel memory: 432K (c0bbf000 - c0c2b000)
Starting UTP
uuc 0.5 [built Dec  3 2015 08:26:46]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
Is there something in kernel config I should tweak for windows to get this device? I have it working with older kernel 3.0.
866 次查看
petarbajic
I have it working on other Windows 7 computers and it also works if I plug it to another USB port, so I'll blame this one on Windows USB driver peculiarity. Thanks.
866 次查看
igorpadykov
Hi Petar
one can check if correct board configuration is selected with *.vbs
file. Also check that you ran ddr test and updated mfg firmware with new board
ddr settings.
866 次查看
petarbajic
Where is this *.vbs file?
I have it working on other Windwos XP and Linux computers, so this issue is either related to Win7 or just my computer. I'll try to reinstall drivers.
867 次查看
petarbajic
