Platform:imx8qxp
Environment:Yocto
currently,I build SD image in Yocto environment.I use dd comand burn SD image into SD card.It was successful and I will found two partitions on SD card.But I have a question.I want to change previous two partition sizes and add a partition at build time.Where can I modify it.
Tks
BRs
Johnny
Hi Xie,
I want to change previous two partition sizes and add a partition at build time,other than using fdisk command manually.
Tks
BRs
Johnny
Hi Joan,
Tks for your comments.
I have solved this issue last week.
Your advice is correct.
BRs
Johnny
