We are thinking to use MCIMX353DJQ5C instead of MCIMX357DJQ5C on our boards.
Will we need to declare something new in barebox/kernel or will it be transparent?
Frederic.
Solved! Go to Solution.
Hi @frk,
As they are pin to pin compatible and the part you are using to replace (MCIMX357DJQ5C) has the same modules, you should not need changes on the software side.
Israel.
Hi @frk,
Israel.
