Replacing MCIMX357DJQ5C by MCIMX353DJQ5C
frk
We are thinking to use MCIMX353DJQ5C instead of MCIMX357DJQ5C on our boards.
Will we need to declare something new in barebox/kernel or will it be transparent?
Frederic.
nxf63675
Hi @frk,
As they are pin to pin compatible and the part you are using to replace (MCIMX357DJQ5C) has the same modules, you should not need changes on the software side.
Israel.
nxf63675
Hi @frk,
Israel.
