Reboot recovery does not work
2,266 次查看
nishigandhapati
We are using  i.MX6Q,  rev 1.2
I am attemptig to install OTA package using "recovery".
I copied the OTA_pkg.zip in /cache directory and then ran "adb reboot recovery"
It enters the REcovery mode, finds the command file that I have created for recovery but then recovery get killed by signal 11 and enters in this loop. From the logs:
init: Starting service 'recovery'...
init: Service 'recovery' (pid 217) killed by signal 11
init: Service 'recovery' (pid 217) killing any children in process group
init: Untracked pid 218 exited with status 1
init: Service 'recovery' (pid 219) killed by signal 11
init: Service 'recovery' (pid 219) killing any children in process group
init: Untracked pid 220 exited with status 1
Could you please help.
We need t use recovery mode for software installation
Nishi
标记 (2)
5 回复数
1,857 次查看
nishigandhapati
radhika.somaiya@volansystech.com‌ I am doing exactly same steps as you listed. Still I am getting same errors. (Please refer to my first msg in this post for logs).
Nishi
1,857 次查看
rakesh_patel
Senior Contributor I
Hi @nishigandha patil;
Can you please confirm following points:
1) Based on message "init: Service 'recovery' (pid 217) killed by signal 11", I think issue may be related to package.
Are you using which OTA package? Your custom package or any reference package comes with NXP's android source code(do "make otapackage" in android source code to generate ota package).
Can you please try for default ota package once?
2) Does your OTA packages only not working with Android 7.1.2 Nougat? Did you tried for any latest Android version?
Thanks.
Rakesh
1,857 次查看
radhikasomaiya
Senior Contributor II
Hi nishigandha patil,
Hope you have tried to update OTA by following steps :
  • Copy the OTA zip package to the device in sdcard using below command :
        $adb push <local> <remote "/sdcard">
  • Move the package from sdcard to cache partition i.e.
       $mv /sdcard/<your zip> /cache/.
  • Make the directory and perform the below steps on device
  • mkdir -p /cache/recovery
  • touch /cache/recovery/command
  • echo "--update_package=/cache/update.zip" > /cache/recovery/command
  • reboot recovery
Above steps will perform the Updation by Android recovery (automatically).
Let me know if you still face any error.
1,857 次查看
nishigandhapati
Hi Diego,
We are using Android 7.1.2 Nougat.
Nishi
1,857 次查看
diegoadrian
Wich Android version are you using?
Diego.
