I have a custom board with imx28 (287) and sgtl5000, kernel 4.
sound codec sgtl5000.
while in playback while performing a song at random
the audio stops feeling.
the kernel hooks the codec properly start and for a while everything seems to work as it should.
some advice??
thank you
excuse for my easy english
Giacomo
It might be the effect of the SGTL5000 silicon erratum in case of using the internal VDDD regulator. Please check. The erratum itslef is described in the SGTL5000 Silicon Errata document, available on the SGTL5000 Documentation web page:
Artur
I verified,
when he stops playing records
ANA_CTRL (0x0024) and ANA_POWER (0x0030) of SGTL return to their default values 0x0111 and 0x7060, with devices switched off.
why can go to reset or return to the default values in those registers
thank you
Giacomo
