Problem testing modifs in yocto
903件の閲覧回数
aaronpadilla
Hi everybody,
I am facing a problem modifying and testing for remapping my debug uart, so I am modifying .config, device tree and u-boot include files, below the location of files modified:
/home/aaron/fsl-arm-yocto-bsp_2/build-x11/tmp/work/imx6dqscm_1gb_qwks-poky-linux-gnueabi/linux-imx/3.14.52-r0/build/.config
/home/aaron/fsl-arm-yocto-bsp_2/build-x11/tmp/work/imx6dqscm_1gb_qwks-poky-linux-gnueabi/u-boot-imx/2015.04-r0/git/include/configs/mx6dqscmqwks.h
/home/aaron/fsl-arm-yocto-bsp_2/build-x11/tmp/work-shared/imx6dqscm-1gb-qwks/kernel-source/arch/arm/boot/dts/imx6dqscm-1gb-qwks-rev2-fix-ldo.dts
Buy the problem is at compilation time, if I run a  bitbake image compilation like:
bitbake core-image-minimal or bitbake -f core-image-base
Nothing changes in the deploy folder, then if I run a forced clean compilation
bitbake -c clean core-image-base
the generated .sdcard file is updated but I think that my modifications are not compiled
If I modify something in the source/somelayer/conf... the bitbake image ovverrides my modifications
I have tried too with the fsl-image-qt5
So, what is the correct procedure to modify some things like uboot, device tree, kernel config in the build folder and then force a compilation without update the files from the source?
Thanks in advance,
Aaron
ラベル(3)
616件の閲覧回数
jimmychan
You can compile the kernel only.
For your reference.
Useful bitbake commands
https://community.nxp.com/docs/DOC-95045
