I am porting Android Automotive from the imx8qm_mek board to our custom board.
I have build a custom scfw_tcm.bin file, as described in the Android_Auto_User_Manual, sec 8.7.
I placed the resulting bin file in ${MY_ANDROID}/vendor/nxp/fsl-proprietary/uboot-firmware/
imx8q_car/mx8qx-custom-scfw-tcm.bin
How do I tell the build scripts to copy this file to /vendor/nxp-opensource/uboot-imx/scfw_tcm.bin during the build process?
When I build, I get the warning "...scfw_tcm.bin' not found, resulting binary is not-functional".
Somehow neither my new file or the original mx8qm-scfw-tcm.bin file are being used.
No luck. I tried:
PRODUCT_COPY_FILES += \
$(FSL_PROPRIETARY_PATH)/fsl-proprietary/uboot-firmware/imx8q_car/mx8qm-custom-scfw-tcm.bin:$(UBOOT_IMX_PATH)/uboot-imx/scfw_tcm.bin \
$(FSL_PROPRIETARY_PATH)/fsl-proprietary/uboot-firmware/imx8q_car/mx8qm-custom-scfw-tcm.bin:$(UBOOT_IMX_PATH)/uboot-imx/mx8qm-custom-scfw-tcm.bin
and
$(FSL_PROPRIETARY_PATH)/fsl-proprietary/uboot-firmware/imx8q_car/mx8qm-custom-scfw-tcm.bin:scfw_tcm.bin \
$(FSL_PROPRIETARY_PATH)/fsl-proprietary/uboot-firmware/imx8q_car/mx8qm-custom-scfw-tcm.bin:mx8qm-custom-scfw-tcm.bin
The only thing that's worked so far is to copy the files manually and set them to read only so they don't get wiped by the clean phase. Then it will compile.
Follow below code in mek_8q_car2.mk
$(FSL_PROPRIETARY_PATH)/fsl-proprietary/uboot-firmware/imx8q_car/xen:xen
