Porting AGL(Automotive Grade Linux) onto I.MX8QXP
4,263 次查看
YoshihisaSaitou
I have i.mx8QXP MEK board.
I want to port AGL on to our I.MX8 based board .Can any one suggest where to start and where to get the base Kernel package for it?
saito
3,768 次查看
joanxie
7 回复数
1,426 次查看
intelav
Above given link is not working for us . We also are using i.MX 8QuadXPlus MEK kit . Please guide us how to enable AGL onto this.
3,769 次查看
joanxie
pls refer to the link as below:
meta-nxp-agl - i.MX Yocto Project AGL Demo Layer
3,768 次查看
YoshihisaSaitou
Dear Joan Xie,
Thank you for your reply.
Is this content also usable with i.mx8qxp?
There is a comment below.
> This image has only been run on i. MX 6QP Saber and Saber Auto.
saito
3,768 次查看
joanxie
this image only tested on the imx6, haven't tested on the imx8qxp, but refer to the 4.9.88 release note, agl image is supported by imx6 and imx8qx auto board
3,768 次查看
YoshihisaSaitou
Dear Joan Xie,
I used i.mx8 and tried at 4.9.88.
but, I got the following error.
How is this error best avoided?
Please tell me how to do it.
I think that is a problem that is caused by the version of Qt.
======error log =====
DEBUG: Executing shell function do_compile
NOTE: VERBOSE=1 cmake --build /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build --
/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot-native/usr/bin/cmake -H/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git -B/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build --check-build-system CMakeFiles/Makefile.cmake 0
/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_progress_start /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/CMakeFiles /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory '/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build'
make -f protocol/CMakeFiles/ivi-application.dir/build.make protocol/CMakeFiles/ivi-application.dir/depend
make[2]: Entering directory '/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build'
cd /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build && /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git/protocol /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/protocol /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/protocol/CMakeFiles/ivi-application.dir/DependInfo.cmake --color=
make[2]: Leaving directory '/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build'
make -f protocol/CMakeFiles/ivi-application.dir/build.make protocol/CMakeFiles/ivi-application.dir/build
make[2]: Nothing to be done for 'protocol/CMakeFiles/ivi-application.dir/build'.
[ 5%] Built target ivi-application
make -f protocol/CMakeFiles/ivi-extension-protocol.dir/build.make protocol/CMakeFiles/ivi-extension-protocol.dir/depend
cd /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build && /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git/protocol /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/protocol /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/protocol/CMakeFiles/ivi-extension-protocol.dir/DependInfo.cmake --color=
make -f protocol/CMakeFiles/ivi-extension-protocol.dir/build.make protocol/CMakeFiles/ivi-extension-protocol.dir/build
make[2]: Nothing to be done for 'protocol/CMakeFiles/ivi-extension-protocol.dir/build'.
[ 27%] Built target ivi-extension-protocol
make -f weston-ivi-shell/CMakeFiles/ivi-controller.dir/build.make weston-ivi-shell/CMakeFiles/ivi-controller.dir/depend
cd /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build && /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git/weston-ivi-shell /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/weston-ivi-shell /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/weston-ivi-shell/CMakeFiles/ivi-controller.dir/DependInfo.cmake --color=
make -f weston-ivi-shell/CMakeFiles/ivi-controller.dir/build.make weston-ivi-shell/CMakeFiles/ivi-controller.dir/build
[ 28%] Building C object weston-ivi-shell/CMakeFiles/ivi-controller.dir/src/ivi-controller.c.o
cd /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/weston-ivi-shell && /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot-native/usr/bin/aarch64-poky-linux/aarch64-poky-linux-gcc -Divi_controller_EXPORTS -I/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git/weston-ivi-shell/src -I/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/weston-ivi-shell -I/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/protocol -I/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot/usr/include/weston -I/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot/usr/include/libweston-3 -I/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot/usr/include/pixman-1 -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0=/usr/src/debug/wayland-ivi-extension/2.0.2-r0 -fdebug-prefix-map=/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot= -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/recipe-sysroot -fPIC -o CMakeFiles/ivi-controller.dir/src/ivi-controller.c.o -c /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git/weston-ivi-shell/src/ivi-controller.c
/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git/weston-ivi-shell/src/ivi-controller.c: In function 'controller_screenshot_notify':
/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git/weston-ivi-shell/src/ivi-controller.c:1284:42: error: incompatible type for argument 7 of 'ivi_screenshot_send_done'
shm_format, output->frame_time);
In file included from /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/git/weston-ivi-shell/src/ivi-controller.c:39:0:
/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build/protocol/ivi-wm-server-protocol.h:314:1: note: expected 'uint32_t {aka unsigned int}' but argument is of type 'struct timespec'
ivi_screenshot_send_done(struct wl_resource *resource_, int32_t fd, int32_t width, int32_t height, int32_t stride, uint32_t format, uint32_t timestamp)
weston-ivi-shell/CMakeFiles/ivi-controller.dir/build.make:65: recipe for target 'weston-ivi-shell/CMakeFiles/ivi-controller.dir/src/ivi-controller.c.o' failed
make[2]: *** [weston-ivi-shell/CMakeFiles/ivi-controller.dir/src/ivi-controller.c.o] Error 1
CMakeFiles/Makefile2:315: recipe for target 'weston-ivi-shell/CMakeFiles/ivi-controller.dir/all' failed
make[1]: *** [weston-ivi-shell/CMakeFiles/ivi-controller.dir/all] Error 2
make[1]: Leaving directory '/home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/build'
Makefile:132: recipe for target 'all' failed
make: *** [all] Error 2
WARNING: exit code 2 from a shell command.
ERROR: Function failed: do_compile (log file is located at /home/a/imx-yocto-bsp/bld-agl/tmp/work/aarch64-mx8qxp-poky-linux/wayland-ivi-extension/2.0.2-r0/temp/log.do_compile.81381)
saito
3,768 次查看
YoshihisaSaitou
Dear Joan Xie,
OK.
I will try.
saito
3,714 次查看
guruvendrachowd
Do u find any solution for above error ?
