PWM Control
PWM Control
569件の閲覧回数
charleshuang
Senior Contributor II
Hi NXP,
We are now using imx93 to use LVDS, and we need to use the PIN of PWM TPM3. In the EVK version,
we do not see the definition of the relevant TPM3 PIN. Please tell me how to use it.Currently there is no definition of TPM3 pin in the following files.
arch/arm64/boot/dts/freescale/imx93.dtsi
drivers/clk/imx/clk-imx93.c
include/dt-bindings/clock/imx93-clock.h
Please tell me what settings need to be made if you want to use TPM3 to set pwm output.
548件の閲覧回数
joanxie
current bsp only uses tpm4 as pwm, for tpm3, maybe you can try this
tpm3: pwm@424e0000 {
compatible = "fsl,imx7ulp-pwm";
reg = <0x424e0000 0x1000>;
clocks = <&clk IMX93_CLK_TPM3_GATE>;
 assigned-clock-parents = <&clk IMX93_CLK_24M>;
ssigned-clock-rates = <24000000>;+
#pwm-cells = <3>;
status = "disabled";
