PF0100 - LDO Specs.
PF0100 - LDO Specs.
1,046 次查看
davidkearney
Hi there, I'm looking for detailed specs on the six LDOs featured in the PF0100. I can't find info such as Drop Out Voltage, Power Supply Ripple Rejection (PSRR) in the datasheet - is there somewhere where I could  find this info?
Many Thanks,
Dave
954 次查看
igorpadykov
Hi David
please refer to (use VGEN4 as example) Table 105. VGEN4 electrical characteristics MMPF0100 Datasheet
http://cache.freescale.com/files/analog/doc/data_sheet/MMPF0100.pdf
Drop Out Voltage is described in VIN2 Operating input voltage: VGEN4NOM+ 0.250V
955 次查看
igorpadykov
Hi David
954 次查看
davidkearney
Thanks Igor, thats what i was looking for!
