PCIE network card
PCIE network card
1,278 次查看
carmilili
I plug a mPCIe network card on the board IMX6Q-SDB.
The mPCIE card is RTL8111e or RTL8111f.The code is r8168-8.038.00.
It only work well when use the command of ping,tftp iperf and ssh run failure.
PCIE: imx_pcie_pltfm_probe start link up.
IMX PCIe port: link up.
pci 0000:00:00.0: [16c3:abcd] type 1 class 0x000604
pci 0000:00:00.0: reg 10: [mem 0x00000000-0x000fffff 64bit pref]
pci 0000:00:00.0: reg 38: [mem 0x00000000-0x0000ffff pref]
pci 0000:00:00.0: supports D1
pci 0000:00:00.0: PME# supported from D0 D1 D3hot D3cold
pci 0000:00:00.0: PME# disabled
PCI: bus0: Fast back to back transfers disabled
pci 0000:01:00.0: [10ec:8168] type 0 class 0x000200
pci 0000:01:00.0: reg 10: [io  0x0000-0x00ff]
pci 0000:01:00.0: reg 18: [mem 0x00000000-0x00000fff 64bit pref]
pci 0000:01:00.0: reg 20: [mem 0x00000000-0x00003fff 64bit pref]
pci 0000:01:00.0: supports D1 D2
pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:01:00.0: PME# disabled
PCI: bus1: Fast back to back transfers disabled
pci 0000:00:00.0: BAR 0: assigned [mem 0x01000000-0x010fffff 64bit pref]
pci 0000:00:00.0: BAR 0: set to [mem 0x01000000-0x010fffff 64bit pref] (PCI addr
ess [0x1000000-0x10fffff])
pci 0000:00:00.0: BAR 9: assigned [mem 0x01100000-0x011fffff pref]
pci 0000:00:00.0: BAR 6: assigned [mem 0x01200000-0x0120ffff pref]
pci 0000:00:00.0: BAR 7: assigned [io  0x1e00000-0x1e00fff]
pci 0000:01:00.0: BAR 4: assigned [mem 0x01100000-0x01103fff 64bit pref]
pci 0000:01:00.0: BAR 4: set to [mem 0x01100000-0x01103fff 64bit pref] (PCI addr
ess [0x1100000-0x1103fff])
pci 0000:01:00.0: BAR 2: assigned [mem 0x01104000-0x01104fff 64bit pref]
pci 0000:01:00.0: BAR 2: set to [mem 0x01104000-0x01104fff 64bit pref] (PCI addr
ess [0x1104000-0x1104fff])
pci 0000:01:00.0: BAR 0: assigned [io  0x1e00000-0x1e000ff]
pci 0000:01:00.0: BAR 0: set to [io  0x1e00000-0x1e000ff] (PCI address [0x1e0000
0-0x1e000ff])
pci 0000:00:00.0: PCI bridge to [bus 01-01]
pci 0000:00:00.0:   bridge window [io  0x1e00000-0x1e00fff]
pci 0000:00:00.0:   bridge window [mem disabled]
pci 0000:00:00.0:   bridge window [mem 0x01100000-0x011fffff pref]
(1)
root@freescale /app/net$ifconfig
eth0      Link encap:Ethernet  HWaddr 00:04:9F:02:6E:25
          inet addr:192.168.2.67  Bcast:192.168.2.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:109724 errors:0 dropped:903 overruns:0 frame:0
          TX packets:7501 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:17633802 (16.8 MiB)  TX bytes:1108875 (1.0 MiB)
eth1      Link encap:Ethernet  HWaddr 00:13:3B:0E:D1:10
          inet addr:10.0.0.1  Bcast:10.255.255.255  Mask:255.0.0.0
          RX packets:18112 errors:0 dropped:142 overruns:0 frame:0
          TX packets:23 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1537208 (1.4 MiB)  TX bytes:1494 (1.4 KiB)
          Interrupt:155 Base address:0xe000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:14 errors:0 dropped:0 overruns:0 frame:0
          TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1136 (1.1 KiB)  TX bytes:1136 (1.1 KiB)
(2)
root@freescale /app/net$ ping 10.0.0.2
PING 10.0.0.2 (10.0.0.2): 56 data bytes
64 bytes from 10.0.0.2: seq=0 ttl=64 time=10.165 ms
64 bytes from 10.0.0.2: seq=1 ttl=64 time=0.230 ms
It is ok.
(3)
When I use the commad tftp ssh and iperf to test it ,all to be  failure.
root@freescale /app/net$ ssh -v root@10.0.0.2
OpenSSH_4.3p2, OpenSSL 1.0.1c 10 May 2012
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Connecting to 10.0.0.2 [10.0.0.2] port 22.
debug1: Connection established.
debug1: permanently_set_uid: 0/0
debug1: identity file /root/.ssh/identity type -1
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_5.3
debug1: match: OpenSSH_5.3 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_4.3
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
It  stops  here.
标签 (3)
867 次查看
Oceanblue
Hi Carmili,
     I have met the similar issue to you, have you solved the problem? please share if solved, thanks.
867 次查看
carmilili
     It is only in the test now.
867 次查看
igorpadykov
Hi Carmili
I would suggest to upgrade RTL8111 driver or
try to use more new kernel.
L3.10.17_1.0.0_IMX6QDLS_BUNDLE : Source Code
chip
