We are also looking for Mini Pci-e modem for the imx6slevk. Did you manage to find a suitable solution?
Many Thanks,
Nigel
Hi Nigel,
We have tested Huawei's MU609 module with SLEVK.
However, you may need additional support from Huawei for testing different features.
And also, the module length will be little longer such that it will extent outside the EVK, need to handle carefully while operating.
Pankaj Rana
Hi Pankaj,
Thanks for the advice! I have bought a MU609 module and I see what you mean by the module length. Not a problem though.
Can you advise where to begin with including the driver? I am using Freescale latest Android BSP.
Many Thanks,
Nigel
Hi Nigel,
Hoping that you have the "Guide to Kernel Driver Integration" document from Huawei, we referred the same.
FYI , we worked on the Linux Yocto Kernel 3.10.53.
You may have to develop a serial application or make use of Minicom.
Pankaj Rana
Hi Pankaj,
Yes we found that document after posting.
Many Thanks,
Hi Pankaj
miniPCIe 3G modem Huawei EM770W
mentioned in documentation.
Dear igorpadykov ,
Few Queries:
Pankaj Rana
Hi Pankaj
suggest to check
http://comments.gmane.org/gmane.linux.embedded.yocto.meta-freescale/13073
(support for Huawei MU609 USB modem)
~igor
Dear Igor,
As per the Sololite EVK we have, it looks like the module has to be Half Mini PCIe Form Factor (26.7x30x4.5mm), whereas the Huawei EM770W is Mini PCIe(51x30x4.5mm). Please let me know whether any Half Mini PCIe Module was Tested with the SoloLite EVK.
Many Thanks.
Pankaj Rana
