Hi all I'm designing a system with i.MX6Solo. And I'm concerned about the delay from camera input to display output. My system has two lines. One line is camera through that is including from YUV to YCbCr format conversion. The other is encoding camera input (720P@30Hz) in H.264 and save to SD card. The system will operate at the same time. Then, I have a question about a above system. Is the maximum system delay can be achieved within 2 frame? Addition to above, is there any possibility to achieve within 1 frame? Please give your opinion. Just for information, I found a following contribution. But no one answered. https://community.freescale.com/message/451281#451281 Best Regards,
解決済! 解決策の投稿を見る。
Hi ko-hey
I am afraid delay can not be achieved within 2 frames, in general
VPU latency encoding is about 3 frames but may be bigger depending
on used algorithm. For example one can check below links
http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
http://mewiki.project357.com/wiki/X264_Encoding_Suggestions#Encoder_latency
Hi Igor
Thank you for your reply.
I understood H.264 needs about 3 frames.
As described above, I have two lines in my system.
One doesn't need H.264 compression.
In that line, do you think it also can't achieve 2 frames?
Hi ko-hey
without VPU I think it
can achieve 2 frames.
~igor
Hi Igor
Thanks.
How about within 1 frame? Can it achieve?
If you have any experience, please let me know.
ko-hey
