Dear NXP Team,
I am migrating to the latest BSP release :
In drivers/staging/media/imx/imx8-isi-cap.c :
* Pixel link input format
struct mxc_isi_fmt mxc_isi_src_formats[] = {
.name = "RGB32",
.fourcc = V4L2_PIX_FMT_RGB32,
.depth = { 32 },
.memplanes = 1,
.colplanes = 1,
.align = 2,
.name = "YUV32 (X-Y-U-V)",
.fourcc = V4L2_PIX_FMT_YUV32,
.depth = { 32 },
.memplanes = 1,
.colplanes = 1,
.align = 2,
+ .name = "RAWRGB10 (SRGGB10)",
+ .fourcc = V4L2_PIX_FMT_SRGGB10,
+ .depth = { 16 },
+ .memplanes = 1,
+ .colplanes = 1,
+ .align = 3,
And in drivers/staging/media/imx/imx8-isi-fmt.c
struct mxc_isi_fmt mxc_isi_out_formats[] = {
.name = "RGB565",
.fourcc = V4L2_PIX_FMT_RGB565,
.depth = { 16 },
.color = MXC_ISI_OUT_FMT_RGB565,
.memplanes = 1,
.colplanes = 1,
.align = 3,
.mbus_code = MEDIA_BUS_FMT_RGB565_1X16,
.name = "RGB24",
.fourcc = V4L2_PIX_FMT_RGB24,
.depth = { 24 },
.color = MXC_ISI_OUT_FMT_BGR32P,
.memplanes = 1,
.colplanes = 1,
.align = 2,
.mbus_code = MEDIA_BUS_FMT_RGB888_1X24,
.name = "BGR24",
.fourcc = V4L2_PIX_FMT_BGR24,
.depth = { 24 },
.color = MXC_ISI_OUT_FMT_RGB32P,
.memplanes = 1,
.colplanes = 1,
.align = 2,
.mbus_code = MEDIA_BUS_FMT_BGR888_1X24,
.name = "YUYV-16",
.fourcc = V4L2_PIX_FMT_YUYV,
.depth = { 16 },
.color = MXC_ISI_OUT_FMT_YUV422_1P8P,
.memplanes = 1,
.colplanes = 1,
.align = 3,
.mbus_code = MEDIA_BUS_FMT_YUYV8_1X16,
.depth = { 32 },
.color = MXC_ISI_OUT_FMT_YUV444_1P8,
.memplanes = 1,
.colplanes = 1,
.align = 2,
.mbus_code = MEDIA_BUS_FMT_AYUV8_1X32,
.name = "NV12 (YUYV)",
.fourcc = V4L2_PIX_FMT_NV12,
.depth = { 8, 8 },
.color = MXC_ISI_OUT_FMT_YUV420_2P8P,
.memplanes = 2,
.colplanes = 2,
.align = 4,
.name = "YUV444M (Y-U-V)",
.fourcc = V4L2_PIX_FMT_YUV444M,
.depth = { 8, 8, 8 },
.color = MXC_ISI_OUT_FMT_YUV444_3P8P,
.memplanes = 3,
.colplanes = 3,
.align = 4,
.mbus_code = MEDIA_BUS_FMT_YUV8_1X24,
.name = "xBGR32",
.fourcc = V4L2_PIX_FMT_XBGR32,
.depth = { 32 },
.color = MXC_ISI_OUT_FMT_XRGB32,
.memplanes = 1,
.colplanes = 1,
.align = 2,
.name = "ABGR32",
.fourcc = V4L2_PIX_FMT_ABGR32,
.depth = { 32 },
.color = MXC_ISI_OUT_FMT_ARGB32,
.memplanes = 1,
.colplanes = 1,
.align = 2,
+ .depth = { 16 },
+ .color = MXC_ISI_OUT_FMT_RAW16,
+ .memplanes = 1,
+ .colplanes = 1,
+ .align = 3,
+ .mbus_code = MEDIA_BUS_FMT_SRGGB10_1X10,
Compared to previous 5.10 releases, there''s additional .align field. I would like to know what is the suitable value for the RAW10 format as in the code snippet, please ?
Thanks in advance and best regards,
Khang
I don't get reply, but I read the code and found the patch for align is that bsp team a
4l_bound_align_image, then you can find this function is defined in the
you can focus on the function *w = clamp_align(*w, wmin, wmax, walign), you can to find how to define the clamp_align then figure out what walign is for
