Once I installed and build yocto L3.10.53 for the i.MX6Q-SDB an year ago and it worked at that time.
Today I tried same instructions again then sdcard image updated but boot failed (kernel panic).
What happened while I didn't touch for a while?
Is there any possibility recently released patch cause this issue?
Can anyone help me?
Thanks.
Hi torus1000
If you do not remove any partition or modify the kernel on your SD, could be:
- a damage SD, please try to erase and burn your SD again.
- Bad RAM, defective ram cause kernel panic.
- Check if any peripheral is connected and disconnected before reboot.
Hope this helps
