The following highlighted error message appeared, while loading bin, rootfs and dtb.
It shows Error: inflate() returned -5, during uncompressing Kernel image.
what is the solution ?
Sunder
transferred = 3121682 (2fa212 hex)
=> tftp c00000 p1020wlan.dtb
Speed: 100, full duplex
Using eTSEC1 device
TFTP from server 192.168.1.5; our IP address is 192.168.1.1
Filename 'p1020wlan.dtb'.
Load address: 0xc00000
Loading: #
done
Bytes transferred = 12288 (3000 hex)
=> bootm 2000000 3000000 c00000
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Linux-3.12.19-rt30-QorIQ-SDK-V1.
Created: 2015-02-11 6:34:28 UTC
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 4212480 Bytes = 4 MB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 03000000 ...
Image Name: fsl-image-minimal-p1020rdb-20150
Created: 2015-02-16 15:10:27 UTC
Image Type: PowerPC Linux RAMDisk Image (gzip compressed)
Data Size: 3121618 Bytes = 3 MB
## Flattened Device Tree blob at 00c00000
Booting using the fdt blob at 0xc00000
Uncompressing Kernel Image ... Error: inflate() returned -5
GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover
U-Boot 2009.11 (Jun 21 2011 - 16:07:27)
CPU0: P1020E, Version: 1.1, (0x80ec0011)
Core: E500, Version: 5.1, (0x80212051)
Clock Configuration:
CPU0:800 MHz, CPU1:800 MHz,
CCB:400 MHz,
DDR:333.333 MHz (666.667 MT/s data rate) (Asynchronous), LBC:25 MHz
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Board: P1020SKU
CPLD: V5.0
PCBA: V4.0
I2C: ready
DRAM: Configuring DDR for 666.667 MT/s data rate
DDR: 1 GB
FLASH: 64 MB
L2: 256 KB enabled
MMC: FSL_ESDHC: 0
EEPROM: Invalid ID (ff ff ff ff)
eTSEC2 is in sgmii mode.
PCIE2 connected to ULI as Root Complex (base addr ffe09000)
Scanning PCI bus 01
01 00 168c 0030 0280 ff
PCIE2 on bus 00 - 01
PCIE1 connected to Slot 2 as Root Complex (base addr ffe0a000)
Scanning PCI bus 03
03 00 168c 0030 0280 ff
PCIE1 on bus 02 - 03
In: serial
Out: serial
Err: serial
Net: eTSEC1, eTSEC3
Hit any key to stop autoboot: 0
已解决! 转到解答。
My target is P1020WLAN Board. The U-boot has been compiled as default. There is no change required U-boot.
The existing current version of u-boot from SDKV1.4 has been uploaded.
The document QorIQ-SDK-1.6-IC-RevB is gives the following steps as example
=> setenv ipaddr <ipaddr>
=> setenv serverip <serverip>
=> setenv netmask <netmask>
=> setenv ethaddr <mac-addr>
=> save
=> tftp 1000000 u-boot_9131RDB_NAND_100.bin
=> nand erase 0 100000
=> nand write 1000000 0 $filesize
After flashing the required bootloader:
1. Power off the board.
2. Ensure correct switch settings for NAND boot (SW4 – xxxx1001).
3. Power on the board
JTAG is not available, what is the step to place the u-boot in the alternative bank. Even if something goes wrong, I can use existing one.
