Hello there Greetings.
Kernel:3.10.9
Board: i.MX6 Solo based custom board.
Step 1: load the mass storage driver
insmod g_mass_storage.ko file=/dev/mtdblock5
calling msg_init+0x0/0x1c [g_mass_storage] @ 381
initcall msg_init+0x0/0x1c [g_mass_storage] returned -19 after 1549 usecs
insmod: can't insert 'g_mass_storage.ko': No such device
Step 2: dmesg
calling msg_init+0x0/0x1c [g_mass_storage] @ 388
couldn't find an available UDC
initcall msg_init+0x0/0x1c [g_mass_storage] returned -19 after 1606 usecs
calling msg_init+0x0/0x1c [g_mass_storage] @ 389
initcall msg_init+0x0/0x1c [g_mass_storage] returned -19 after 1570 usecs
I am stuck with this error. Appreciate any pointers ...
Krishnan.
已解决! 转到解答。
Dear Eric,
Thanks for the suggestions. It was a problem with UDC controller driver. I have enabled chip idea hdr controller driver in kernel
Now the g_mass_storage works fine
root@imx6qsabrelite:/# insmod g_mass_storage.ko file=/dev/mtdblock5
calling msg_init+0x0/0x1c [g_mass_storage] @ 421
g_mass_storage gadget: Mass Storage Function, version: 2009/09/11
g_mass_storage gadget: Number of LUNs=1
lun0: LUN: file: /dev/mtdblock5
g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
g_mass_storage gadget: userspace failed to provide iSerialNumber
g_mass_storage gadget: g_mass_storage ready
initcall msg_init+0x0/0x1c [g_mass_storage] returned 0 after 30566 usecs
root@imx6qsabrelite:/# g_mass_storage gadget: high-speed config #1: Linux File-Backed Storage
It looks like I have some problem in VBUS configuration. Th USB_OTG_ID pad was left unconnected on the board.
In the dts file i have added below code to enable OTG support.
&usbotg {
vbus-supply = <®_usb_otg_vbus>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usbotg_1>;
disable-over-current;
status = "okay";
One more experiment done was compiling g_mass_storage driver statically. But at this time I am not able change the file paramter.
In kernel configuration i have selected below options.
under USB Peripheral Controller
<*> Freescale Highspeed USB DR Peripheral Controller
I have added some debug prints in drivers/usb/gadget/udc-core.c where the probe is happening. It says probe could not find USB device controller driver.
I am little lost how to proceed. Any pointers/help will be much appreciated.
Thanks in advance
Krishnan
Hi Krishnan,
This may be an issue with the pad configurations for Solo.
We didn't have support for Dual-Lite/Solo in our 3.10.9 release, but USB OTG was supported on i.MX6Q:
http://boundarydevices.com/imx6-linux-kernel-3-10-9/
We have recently tested on 3.10.17, notably on our Nitrogen6_Lite board:
http://boundarydevices.com/mx6-linux-kernel-3-10-17-beta/
You can compare your configuration against nit6xlite_defconfig and your DTS files against
imx6dl-nit6xlite.dts in in this tree:
We tested using g_ether, not g_mass_storage, but the detection and registration
should be the same.
Hello Eric,
I try to establish 1 HID and 1 mass storage at same time.
I already have enabled "ChipIdea Highspeed Dual Role Controller", HID and mass storage features in kernel(menuconfig). But I get an error message "udc-core: couldn't find an available UDC - added [g_mass_storage] to list of pending drivers".
I try to modified core.c but it's not work. I have trawled through many articles with no luck. Does it have efficient way to modify USB descriptor for 1 HID and 1 Mass Storage at same time?
(imx6ull14x14evk-poky-linux-gnueabi\linux-imx\4.9.11-r0\git\drivers\usb\gadget\udc\core.c)
Thank you.
Situation 1:
Step 1: insmod g_hid.ko <======= HID is work normally
Step 2: insmod g_mass_storage.ko <====== show error message
Situation 2:
Step 1: insmod g_mass_storage.ko <====== mass storage is work normally
Step 2: insmod g_hid.ko <======= show error message
udc-core: couldn't find an available UDC - added [g_hid] to list of pending drivers
You can not load two gadget drivers simultaneously, for this you need to load them as a composite driver, you can do this through configfs or hardcoded on the legacy drivers.
-Marco
Dear Eric,
