Is there any way we can configure IMX6Solo at 400Mhz
1,598 次查看
Yogee
We need to understand how IMX6S would be configured at 400Mhz to make the system at lowest power. LPDDR2 used would be configured at 333Mhz.
Yogee
标记 (1)
4 回复数
1,417 次查看
YixingKong
Senior Contributor IV
Yogee
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
1,417 次查看
YixingKong
Yogee
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
1,417 次查看
AnsonHuang
I think you can just use the powersave governor for cpufreq driver, then cpufreq will be fixed at 396MHz.
echo powersave > /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governor.
1,417 次查看
tonyzheng
Hi, Yogee
you can refer to i.MX_6Solo6DualLite_Linux_Reference_Manual.pdf.
Maybe you can adopt other methods to realize the objective of low-power consumption. And for example, Low-level Power Management driver on Linux.
As far as i know, IMX6Solo hardware supports four low-power modes: RUN, WAIT, STOP, and DORMANT , you can make the CPU run under these low-power modes.
Tony
