eDP ( Embedded DisplayPort) will not support directly to iMX6 CPU. So we need to use a eDP converter/ bridge between the eDP and iMX6.
Please let us know that, whether FSL has tested the eDP with iMX6 ? If tested, could you provide the eDP converter part number ?
Azlum
已解决! 转到解答。
HI Azlum
eDP is not supported natively in hardware, seems one can use
converter like DSI to eDP or similar:
PS8640,42 – MIPI Dual Channel DSI to eDP (paradetech.com/products/displayport-transmitters/ps8642/).
I am not aware of eDP usage with i.MX6.
HI Azlum
