I am using an iMX8QM-MEK board and making a custom SCU Firmware (scfw_tcm.bin). With the debug monitor enabled, upon boot, I get the following error:
"Incorrect SECO FW Version 2.3.1 (2.5.4 or later required)"
This error should be self evident. Nonetheless, I can't seem to find versions of the SCFW Porting Kit and the SECO firmware (mx8qm-ahab-container.img) with these versions.
Things seem to work, but how would I know that they were not. Or maybe there is some feature that I have not yet used which will break.
I am building the SCFW with imx-scfw-porting-kit-1.3.0.
The SECO firmware (mx8qm-ahab-container.img) was extracted from "firmware-imx-8.1".
Am I doing something wrong or can someone please steer me towards two compatible versions of the SECO firmware and the SCFW kit?
Thank you
SECO firmware has been moved from firmware-imx into separate container: https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-seco-2.5.4.bin
what bsp version do you use? let me check the version, it seems your version doesn't match, You can get it using Yocto to fetch firmware-imx package or from this link: https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/*.bin
