You can refer to Installing Ubuntu Rootfs on NXP i.MX6 boards and Ubuntu Rootfs on NXP i.MX6QP boards
What is the value of the vidargs variable in U-Boot?
Use the printenv command to find out
Seems to be low quality video settings
Example of the vidargs variable for iMX6 that I use:
video=mxcfb0:dev=ldb,1280x720M@60,if=RGB888,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=1024M
What is the value of bpp?
Dionevã M. Krolow
Hello. Dionevã Krolow
Thanks for your help , according to your vidargs variable, the display work right.
