Hello comminity,
I am working on imx6 custom board and i want to add ethernet interface.
The evaluations boards from nxp are based on RGMII with AR8031 chip or lan8720.
I need to know :
Does the linux recognizes automatically the phy ethernet even if I choose an other phy components as the ksz8794 or others ?
If driver is needed, how to build and implement it on my custol software?
Is it possible to get some documentations about this ?
Thank you
已解决! 转到解答。
Hi bastien
some specific for each phy ethernet can be required, as for example related to ar8031 codes can be
found in .. arch/arm/mach-imx/mach-imx6q.c, drivers/net/ethernet/freescale/fec_fixup.c
for lan8720 in ..drivers/net/phy/smsc.c :
Porting documentation can be found in
Hi bastien
